Starter makes 1 click on startup
eircrcan,
If you haven't replaced the solenoid yet you might want to check it out. |
Check your initial timing, could be to far advanced.
When you say "click" do you mean just a slight "tap" or does it sound really solid like maybe the starter is not completely engaging the flywheel teeth? A solenoid problem would make a lighter sound than the starter binding on the flywheel but obviously the solenoid itself is OK. This really sounds like an alignment problem causing the starter to bind.
Timing could not be an issue until the engine was already cranking and trying to start. |
I am not sure if it is a tap or click (since i have never had this problem before), but I can clearly hear it when sitting inside the car; so maybe that is a click?
We put the engine together before dropping it in the car, and the teeth were not lining up very well, so we added a shim and it lined up right in the center of the the flywheel teeth. *edit* This is how the flywheel teeth and the starter line up (see attached pic) Last edited by ericrcan; 08-22-2010 at 12:21 PM. |
Well today I went out there, and completely cleaned the battery cables, battery, and all ground connections, but it did the click again, and eventually started up. We drove to the gas station about 2 miles away, put in gas, and came back home. Right after we shut it off, we tried to start it back up again, and nothing. No clicks, no nothing... Im not sure if its hot and the solenoid froze for now, or maybe its an alt or battery problem? The battery is brand new, but the alt is an old one (not quite sure on how old, but looked old...). We could turn it like we were going to start it, and the electric fan could kick on, and we could turn the headlights on and such, but no turning of the starter, or even any clicks.. I was gonig to buy a ignition switch and alternator and try that out, could that be the problem?
If the lights come on and the fan is running then the battery is not discharged so the alternator is not the problem nor would the ignition switch likely be at fault as long as the starter is trying to engage. If it is doing nothing at all it could be a switch problem but considering your previous problem the switch is not likely to be the trouble. Checking the switch is simple enough so you need to do that before buying parts, if you don't have a volt meter now is a darn good time to buy one. It does not have to be an expensive meter, less than ten bucks at Wally World or the like, just something that can check voltage and resistance. Check these parts out before buying anything because it sure can get expensive buying parts you don't need and that can easily happen when you are just guessing.
Today I went out there and tried to use the multimeter the swtich, and this is what I got:
BAT - 12v IGN - when cranked it was at 10 *or close to it* SOL - when cranked it was at 10 *or close to it* I didnt have the accessory wire connected because whoever owned the car before us went crazy wtiht the wiring... I dont get any noise at all from teh starter... This is the 4th one we've tried, and now its stuck out on the street..
The battery is actually currently at 11.47 v, not a full 12.. But right now when I turn the key, there is no clicking, or even starting of the engine, so I cannot check the voltage at the alternator
| starter woes | greenhj | Electrical | 3 | 06-20-2009 10:22 PM |
| 84' 350 SBC Starter Problems | Gokussj5okazu | Engine | 8 | 05-14-2007 05:16 PM |
| Protecting the starter on a sbc | joe350s10 | Engine | 13 | 06-04-2006 04:38 PM |
| 350 starter buzz | VEGA 3503508.5 | Engine | 10 | 04-03-2006 09:36 PM |
| Carry on from other Starter POST | dollybud | Electrical | 0 | 09-26-2003 05:48 PM |
