Starter mesh problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2012, 03:18 PM
So I have a 350/700R4 in my pickup build with a mini HP starter and 168 tooth flexplate. With everything tight and no shims installed I have a gap of about 1/4" from flexplate to starter pinion shaft. Everything I've read has shown that gap needs to be right about 1/8" What can I do to bring these two closer together? I'm hoping to start this thing for the first time within the next month or so.
Thanks!
Old 08-27-2012, 05:56 PM
The correct way to measure for this is to engage the starter gear into the flexplate. Look closely at the flexplate to find the point where one tooth of the starter gear is engaged flush between 2 of the Flexplate gears. Using a round feeler gauge insert it between the tip of the starter gear and the gears of the flexplate. You will need a reading of about .015.
Old 08-27-2012, 06:08 PM
OK so say I did it that way and got a reading 2-3 times what it needed to be. How would you get it to .015?
Old 08-27-2012, 08:56 PM
When you purchased your high torque starter it should have came with some starter shims. You will have to add shims between the block and the starter. To shim it in to the flexplate cut the shim in half and install on outside bolt.
Old 08-28-2012, 10:53 AM
OK that kinda makes sense. I guess by shimming the outside it will bring the angle in tighter to the flexplate. Is there too many shims that I should use? It seems like I will need quite a few to get me where I want to go.
Old 08-28-2012, 12:35 PM
How much space is between the starter and flexplate? If it would take say like 4 shims something is definitely wrong. Are you sure it is the right started for the right flexplate. Flexplates 153T and 168T
Old 08-28-2012, 01:32 PM
Current gap is about 3/32"-1/8"
Yes, it's a matching flexplate and starter 168t
I'll see how many shims it takes this weekend.
Old 08-28-2012, 07:58 PM
Banned User
Refer to these papers:
Issues with your starter? How to.
Old 08-29-2012, 05:58 PM
Thanks!
The 168 tooth starter has a diagonal bolt mount and the 153 is straight, which one is this what you've got?
When you say the gap is 1/4 inch is this the circular or radial distance between the outside edges of the ring gear and starter pinion or is it a linear gap between the facing edges (front to rear direction) of the gears?
At 168 teeth did you count them (teeth that is) or measure the ring diameter which is 12.75 for the 153 tooth ring and 14 inches for the 14?
Bogie
383 Stroker Starter Mesh Problem Answers larryf Engine 3 11-17-2010 05:16 PM
Starter/fly wheel don't mesh Salisdar73 Engine 13 04-25-2006 05:20 PM
Metal Mesh? phattpat Interior 13 12-20-2005 08:10 PM
starter problem ? timing problem? 6speedwagon Engine 1 08-11-2004 11:37 AM
z06 corvette mesh/screen 61wagonair General Rodding Tech 1 06-12-2003 04:09 PM
