Starter motor. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2008, 09:59 AM
mrdreex's Avatar
Starter motor.
How can I tell how many teeth flywheel my starter is meant for? It's a rebuilt GM unit it looks like, very big. Got it included in a car not too long ago. Is there any way to tell by counting the gears? Thanks!
Old 10-24-2008, 11:30 AM
406 bug's Avatar
9.82 @ 139mph
Does not matter - Its not the teeth on the starter its the mounting the differs on the starter.
Old 10-24-2008, 11:56 AM
mrdreex's Avatar
ok. How is it different? Is it the angle in which it mounts at and contacts the flywheel teeth?
Old 10-24-2008, 12:11 PM
406 bug's Avatar
9.82 @ 139mph
Go to Powerhouse Starters on the web. you will find all the info you ever wanted to know.
Old 10-24-2008, 12:19 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
The mounting is different in that the 168 tooth ring gear
uses a starter with offset bolt holes, the 153 tooth ring gear
uses a starter with paralleled bolt holes,
Rich
Old 10-24-2008, 02:07 PM
406 bug's Avatar
9.82 @ 139mph
Originally Posted by richard stewart 3rd
Hi,
Rich
Most blocks are drilled for both . I have a 168 tooth and the starter has parallel holes.
Old 10-24-2008, 02:15 PM
mrdreex's Avatar
Cool. Thanks for the help, I will look and see what I have later on tonight.
Old 10-24-2008, 02:55 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Offset mounting holes are for the 168 (big) flywheel
Inline mounting holes are for the small flywheel
Cheap GM HVAC blower motor fix. M&M CUSTOM Electrical 8 05-17-2009 11:10 AM
The D.O.T. gonna gitcha. coldknock Hotrodders' Lounge 32 10-31-2007 06:33 AM
A quick question about titles and legal stuff. rusty105 Hotrodding Basics 71 05-04-2007 09:13 AM
Starter motor giving me trouble hollywood2k Engine 3 11-19-2006 01:46 PM
502 crate motor starter edubois Electrical 0 01-07-2003 08:36 PM
