starter motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2010, 09:03 PM
starter motor
hey everyone
i have a 350 chev in my ski boat and im having trouble gettting it fire, it will wind over for about 1min or 2 then it will eventually fire and run perfect. ive checked all the plugs and leads but they seem fine. im also having trouble with my starter motor when i was pulling the plugs out to see if there was water in the block, the starter motor wasnt coming onto the flywheel until i pulled on the starter a lil and it went fine.
if you can help ith any of this thanks alot
Old 02-23-2010, 10:05 PM
Wiki Edits: 27
fuel
Is it taking a while to get fuel. squirt a little in the intake and see if it fires sooner. I used a carry a squirt can of gas in my corvair powered dunebuggy I thing the fuel drained back into the tank. poor check valve operation of the fuel pump or carb needle valve
Old 02-24-2010, 12:20 AM
im thinkin it is getting enought fuel becayse once it starts it runs fine so it seems to be no blockages. i was just playing with it and as i was turning i over is kinda seems that is struggling to turn it over. like the fly wheel is moving slower then normal then it kinda frees it self and fires
Old 02-24-2010, 06:48 AM
bondo's Avatar
Ayuh,... Your wiring is corroded...
Remove, sand, clean, reinstall,+ Grease ALL the starters wiring connections,...
Including the Ground path....
My guess is,... It'll Spin right over then.....
Cheap GM HVAC blower motor fix. M&M CUSTOM Electrical 8 05-17-2009 11:10 AM
The D.O.T. gonna gitcha. coldknock Hotrodders' Lounge 32 10-31-2007 06:33 AM
A quick question about titles and legal stuff. rusty105 Hotrodding Basics 71 05-04-2007 09:13 AM
Starter motor giving me trouble hollywood2k Engine 3 11-19-2006 01:46 PM
502 crate motor starter edubois Electrical 0 01-07-2003 08:36 PM
