Starter Motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2011, 09:36 PM
sscardino's Avatar
SF48
Starter Motor
I replaced the starter motor on my 1968 Chevy 372 motor, the car started right up. I then disconnected the battery and did some minor maintenance on the car. Now it won't start, no clicking no nothing. I attempted to jump the starter w/a screw driver, then it stuck in on position. The motor was running, starter didn't kick back out. It was a grinding sound...
Any Thoughts, Ideas, Opinions?!
Old 05-23-2011, 11:22 AM
starter motor
there is a red wire the that connnects to the positive battery terminal from the fender by the battery that runs to the ignition switch switch. nothing will work without that wire not being connected. i just replaced my starter yesterday and the same thing happened to me. i hope you have a warenty for that starter motor and i hope you didnt grind any flyway teeth off. try to find that wire first and you should be able to start it from inside the cab.
starter motor e5150ryco Electrical 2 04-09-2011 03:38 AM
starter motor J_taylor Engine 3 02-24-2010 06:48 AM
Starter motor. mrdreex Engine 7 10-24-2008 02:55 PM
Starter Motor for chevy 210 Just For Fun Electrical 6 08-28-2005 04:48 PM
need a starter motor FoxThunder 5.0 Hotrodders' Lounge 1 02-21-2003 12:03 PM
