Starter motor has me stumped! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2011, 07:43 PM
Last journal entry: Bringing home the 401 Nailhead
Just a regular GM starter with attached solenoid. It acted up twice last season but now it does it all the time. When I bump the starter with my remote starter or the key and let go the starter continues to turn the engine over untill I disconnect the battery. I suspected the solenoid so I cleaned the contacts to no avail. I installed a new solenoid. Same thing. I disconnected all the wires except the hot from the battery and bumped it with the remote. Still continues to turn the engine over. I thought maybe it was binding against the flywheel somehow and not letting the bendix retreat even though I have had it out a dozen times and cleaned everything. I even left it loose on the bolts but still continued to crank the engine till I disconnected the battery. The bendix does retreat if the engine fires.
It does work fine on the bench. I am stumped and welcome any suggestions.
Old 05-09-2011, 08:09 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Sounds like the ignition switch to me. JMO
Is your battery up to full charge also ?
Cole
Old 05-09-2011, 08:32 PM
HeyJude. (That should be a song) If you disassemble the starter you will probably find that the twist area of the shaft is dry or worn and binding the drive once it sees pressure, or, it could be the inside of the drive where it slides on the shaft. I've seen it a number of times as has anyone who's not just a parts hanger. Clean the shaft and, if it's not too worn, lube it a bit, check inside the drive also where there are several little nubs that ride in the twists of the shaft.
Old 05-09-2011, 08:42 PM
EOD Guy's Avatar
factory or after market remote starter? Might be your problem
Old 05-10-2011, 03:49 AM
Cole
Thanks but I took the ignition out of the equation when I disconnected all the wires from the starter except the positive battery cable. My remote starter is just a jumper across the solenoid contacts.
Old 05-10-2011, 03:51 AM
What I am calling a remote starter is just a switch that you squeeze and it jumps the contacts of the solenoid.
Old 05-10-2011, 03:54 AM
Thanks. I checked and lubed the shaft but never thought to remove the drive and look at the inside. You may have just solved it. Will check this evening.
Old 05-10-2011, 12:54 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Also check the return springs.
vicrod
starter motor e5150ryco Electrical 2 04-09-2011 03:38 AM
Im stumped! motor cranks but wont start BluOX Engine 48 02-12-2011 06:57 AM
Stumped! Need help with stumbling TPI motor DaSouthWon Engine 53 10-27-2008 09:34 PM
Stumped...Motor clsscsb Engine 7 03-16-2004 12:44 AM
need a starter motor FoxThunder 5.0 Hotrodders' Lounge 1 02-21-2003 12:03 PM
