starter not meshing on 383 sbc stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2010, 07:22 PM
383 sbc stroker starter motor motor not meshing properly.its only engaging halfway to the root of the teeth.also jams when i try to engage it under power.i have seen 2-3year old posts with same problems. this is the base 010 block.was a1975 cube van motor.153original i think now a 168 externally balance .not rocket science.
Old 09-13-2010, 07:30 PM
randolphi's Avatar
Possibley the spring, in the relay out off round or bent, with the solenoid removed,( starter out of engine) does the gear travel completely rearward?
Old 09-13-2010, 07:54 PM
starter drive not meshing fully into ring gear.only halfway new starter proper bolts.checking without selenoid and under power,then it jams .seen other posts with 383 strokers having same problems. thanks .not rocket science
1970 383 SBC stroker converted to meet emmissions?? DJB Engine 6 04-15-2010 09:43 PM
87 sbc 377 stroker In./Ex. balance Q. greenmoonshine Engine 8 06-20-2009 11:01 PM
84' 350 SBC Starter Problems Gokussj5okazu Engine 8 05-14-2007 05:16 PM
383 stroker vs 400 sbc jerry meadors Engine 1 09-13-2006 03:37 PM
New style starter, old sbc engine? Walker Engine 2 08-14-2003 05:16 AM
