starter prob - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 10-20-2007, 03:22 PM
starter prob
hello , all you gear heads out there, im 56 years young , stiil drag racing 40 years latter,im a diesel mech by trade own a 1966 chevelle ss true ss , with 138 code , no clone have owed car since 1969. having problem with starter ,not engaging has new flex plate , new starter and brace on starter, the starter drive is not going in to teeth deep enough , used the paper clip methed witch has alwas worked and yes the flex plate is on the right way helpppppppppppppppppppppppppppppp
Old 10-20-2007, 05:09 PM
poncho62's Avatar
Wiki Edits: 5
welcome.......Best to ask in the engine forum.
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders...this forum is for Introductions so best to ask your question over in the Engine forum.
Old 10-21-2007, 12:33 PM
scrot's Avatar
The drive simply must be stuck on the splined shaft. It happened to me recently. The drive wouldn't engage the ring gear at all. I had to change it right there in a shopping center's parking lot.
See if you can grab a hold of it while someone is turning the key and try to yank it out.
Old 10-21-2007, 02:33 PM
Lost in the 60's
Wiki Edits: 4
Sounds like a good way to tear up a hand to me.
Old 10-21-2007, 02:44 PM
scrot's Avatar
(With pliers)
Disconnect the cable that feeds the armature. The drive will try to engage WITHOUT TURNING.
Old 10-21-2007, 02:51 PM
poncho62's Avatar
Wiki Edits: 5
My feelings exactly............pull the starter and fix it properly.
Chevy 350 cracked starter mounting hole w pics skiprec Engine 14 11-11-2011 06:47 AM
Installing a mini starter on my Chevy vern kelly Electrical 5 09-09-2009 02:41 PM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 08:07 PM
Starter questions zipfactor Engine 6 08-07-2005 07:10 AM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 05:48 PM
