Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - starter problem
Thread: starter problem
Old 03-20-2012, 08:19 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
Make sure the battery cables are good and the connections to the battery are clean.
Remove cables, clean with a wire brush. Visual won't tell if it's clean.
If that doesn't work.
Replace hot and ground battery cables. They may look OK but can still be a poor connection on the lug to cable connection.
When cranking put a voltmeter on the battery connection at the starter to make sure your getting full voltage to the starter.
vicrod
The Following User Says Thank You to vicrod For This Useful Post:
the82elco (09-13-2012)
