Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - starter problem
Thread: starter problem
Old 03-21-2012, 03:07 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
I'd try running a temp jumper from the "S" terminal to the ing switch 1st...... if that solves your problem..... well you know what to do then.
Bypassing the fuseable link isn't a good Idea, you can cut out the link and replace it with a 70 amp maxi fuse....which will do the same thing,
