Starter Problem
Help. I just installed a new keep it clean wiring harness in my 57 chevy with a crate 350 motor. Everything works on the car but when I go to cut the car off the starter engages for a brief second or two. I have rechecked all of the wiring and all seems to be straight. It makes the same screeching sound as if the starter/solenoid was going bad when you started a car. I have never experienced that sound when cutting a car off. Any ideas out there? I'm running a mallory hei distributor and msd blaster coil.
Sounds like a bak feed problem. Pull the alternator belt and see if the issue goes away. It is not the final answer obviously but it is a good troubleshooting step
Artificial Intelligence is no match for Natural Stupidity Chet |
Are you sure the starter isn't staying engaged the entire time the engine is running? It might be hard to hear if you have loud exhaust. Just a thought... |
Starter Issue
Thanks for all of the replys. Started by putting on a new starter and solenoid but they didn't work. Decided to try a spare ignition switch I had laying around and that seems to have done the trick though I still cringe when I cut the car off. I'm getting a new 57 switch today and will install it. I did note the temporary switch does have a accessory position whereas an original 57 switch does not have that position. Keeping my fingers crossed that the new wiring isn't doing something to the 57 switch that it can't handle. I will let you know how it turns out.
| Strange Starter Problem | 56xpresso | Engine | 2 | 02-20-2008 04:16 PM |
| Hot soak starter problem | Chevy21 | Engine | 19 | 10-10-2007 11:20 AM |
| small blcok chevy! The ultimate starter problem! S.O.S. | sugar ray | Engine | 12 | 07-19-2007 08:07 PM |
| Starter problem? | opeysgarage | Engine | 3 | 10-03-2003 07:49 PM |
| Big-Block Chevy, "heat soaked" starter problem, HELP!!! | NASCAR314 | Engine | 3 | 04-28-2003 09:18 PM |
