Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter Problems
Old 10-17-2012, 07:45 AM
dasyhard's Avatar
dasyhard dasyhard is offline
Starter Problems
Hey guys, I need some advice on assesing a problem with my starter on my BBC motor. For some time now when starting my motor, my hitachi starter makes screeching sounds, then it would make popping sounds with smoke coming from the starter, not sure where. The car starts but this noise is annoying. I jacked up the car to view the starter and it looks secured but when I checked the flywheel the teeth is worn on the half way mark. And one tooth is completely chipped off. I took some pics and I hope its clear to diagnose what can cause this or is this normal.
ID:	68431   Click image for larger version
