Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter Problems
Old 10-17-2012, 09:05 AM
alittle1 alittle1 is offline
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Incorrect meshing of the starter gear and flywheel teeth.
Pull the spark plugs, remove the coil wire and take off the inspection cover on the flywheel. While using a remote starter switch, go underneath and check for proper gear meshing between the starter and the flywheel. BBC have a 168 tooth flywheel.
Why would you have a Hitachi starter on a GM?
