Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter Problems
Old 10-20-2012, 03:48 PM
LTorree LTorree is offline
I have a similar problem. Changed the starter and still have the meshing noise. Took off the cover plate and disconeted the coil wire and used a jumper starter button to engage the starter to check on the tooth meshing of the starter onto the gear plate. I found out that the outer bolt of the offset starter bolt seemed loose and caused the starter to move when engaging. I tried to tighten but still moved while engaging. Found out that the hole has a crack to which allowed movement of the bolt a little while the starter engaged. Now, my question to the experts would be how do I fix the crack on the block? I hate to change the entire short block. Is it possible to apply a bracket at the end of the starter motor to the block like how some older model chevys use to have? Or is there some sort of epoxy that would fix the crack? Can I use a tap and try and creat a deeper thread and use a longer bolt? Appreciate any help and advice. It is a 96 GMC yukon 5.7 automatic 2 wheel type.
