Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter Problems
Old 10-20-2012, 05:33 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
If you choose to weld repair the cracked/broken starter motor bolt hole boss on the block there is a special alloy welding rod for this. Find a local shop that repairs and welds cast iron.
You will probabily need to remove the engine and bring it to them for repair.
Next time install the support brace.
