Thanks for the info....the vehicle is a prostreet 56 chevy with a 540 Dart block, turbo 400 and Gear Vendors Overdrive. The replacement starter is a MSD 5095 mini starter and the flexplate will be a J.W. Performance Transmissions 93005 168 Tooth Flywheel for Chevy which is what the tech at Summit Racing recommended. You mentioned that aftermarket starters won't match up with your suggested plate, correct? If so, than I'll have to look into what Firebird suggested.
