starter problems?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2010, 06:56 PM
starter problems??
hey guys i've got an 84 chevy truck im building for rock crawling it is a granny gear 4speed and all that stuff but i have a brand new flywheel and starter on it and i have shimmed it and messed with it a thousand times and cant get it right? i can get it to were it starts fine but soon as i drive it then its right back to grinding and wont engage to even turn the motor over if anyone has any tips plz help me out im bout to give up on it
Old 11-23-2010, 06:59 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
What engine ? Are you sure you have the correct starter?
Cole
Old 11-23-2010, 07:08 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Have the correct knurled bolt? Maybe try a bracket on the rear?
Old 11-23-2010, 07:09 PM
its a 350 yes im pretty sure
Old 11-23-2010, 08:54 PM
bubbahotep's Avatar
Could it be too advanced timing? Easy to start cold, impossible to start hot, starter engages but struggles to turn or even grinds on the flywheel.
Old 11-24-2010, 09:11 AM
DoubleVision's Avatar
Been through this a few times and here was my fix.
First off, make sure you have the correct starter bolts.
No washers on the bolts and make sure the bolts are clean.
There are 2 milled flats on the starter where the bolts pass through, the shoulder of the bolt rides on these, make sure both are clean. Install the starter with no shims. Torque the bolts down to 35 ft lbs.
This should take care of it. Adding a factory starter brace would likely be a good idea as well. You can still get these from GM.
Chevy starter problems downonthebayou67 Engine 10 03-29-2010 12:55 PM
350 Starter Problems SBC-Torque Engine 7 01-20-2010 11:25 AM
starter and flywheel problems texasbowhunter2 Hotrodding Basics 3 12-25-2009 02:54 PM
SBC starter problems punk1c5040 Engine 26 12-28-2008 07:58 AM
PLEASE help, starter problems ktusc Engine 6 09-07-2003 07:55 AM
