Starter Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2012, 07:01 AM
Starter Problems
Hi Guys !I Have a 1989 305 TPI Engine, that I put a 700r4 Trans. on the back of it. It has the 153 tooth flex plate on it. I have tried both starters on it the stagered bolt hole puts it too far away from the teeth. The straight bolt is putting it to close, I have tried a stack of shims,but even then the drive is to tight it will come out and wedge into the flex plate. It will not even go in with out the shims. Is there a certain starter that I need to get? PS. I even got a new 153 tooth flexplate for the 305 and still same problem.
Old 11-23-2012, 08:01 AM
bondo's Avatar
Ayuh,... The 12" flex-plate is supposed to use the straight bolt pattern starter,...
My waGuess is, ya mounted the flex-plate, Backwards....
Old 11-23-2012, 10:57 AM
The Flexplate is in with the bumps towards the coverter .
Old 11-23-2012, 11:06 AM
starter problems
Here is some pictures of the flex plate and starter
ID:	69308   Click image for larger version
Starter problems B38 Electrical 3 05-06-2011 04:22 PM
Starter Problems daven66 Engine 6 04-13-2009 06:41 AM
Starter Problems Thumper II Engine 3 08-14-2005 05:07 PM
starter problems bet on black Engine 10 04-20-2005 10:05 AM
starter problems joesnova2 Engine 8 12-29-2002 01:36 PM
