Starter Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2005, 12:52 AM
Checy_Guy's Avatar
Starter Problems
I have a s-10 thats been having some problems starting after it warms up, When its cold it spins over nice but after it warms up it just drags and spins slow. I put a new starter in it and its all shimmed properly, any one know whats causing this?
Chevy-Rules
Old 07-02-2005, 01:01 AM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
How close is the starter solonoid to the exhuast? You may have heat problems from your exhaust and your solonoid once your engine gets warm.
Brad
Old 07-02-2005, 01:14 AM
Checy_Guy's Avatar
I haven't really checked the clearance between them but its all stock exhaust. Do you think i should make some sort of a heat shield?
Chevy-Rules
Old 07-02-2005, 01:18 AM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
It would not hurt.Is your energize wire close to the exhaust manifold.Make sure your wires are pulled down as far as they can from the manifold.
Old 07-02-2005, 01:24 AM
Checy_Guy's Avatar
The wires are all pulled away from the exhaust and they are behind a shield by the manifold.
Chevy-Rules
Old 07-02-2005, 10:42 AM
DoubleVision's Avatar
Add grounds. While this may not seem important, and many don`t give them a second look, it cured my problem, and one of my header tubes is on the starter itself. I ran a 4 gauge ground from the frame to the block, from the block to the battery, a 12 gauge ground from the battery to the fender.
Lastly I used 10 gauge from the frame to the ground on the firewall, and from the firewall to the intake. After doing so it doesn`t matter how hot the outside temp is or how hot the engine gets, the starter still spins the engine over with ease. This also helps the charging system to not have to work as hard so components last longer. I used the brake line hold down bolt in the frame to mount the ground wire, make sure to clean all the connections and use a electrical grease.
Old 07-04-2005, 10:29 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
Solenoid
When buying jobber rebuild starters they use the cheapest parts. A 5 yr warranty starter has a better solenoid than a 2 yr warranty starter. I had a starter in my 350 die on me. I replaced it with a mini-starter. Then, I bought a new expensive solenoid and installed it on the original starter with no other new parts (not even new brushes). That starter has been on my 454 for 2 years now.
SBC Starter and flywheel problems WakBordr7387 Engine 18 03-05-2011 02:13 AM
Chevy starter problems downonthebayou67 Engine 10 03-29-2010 12:55 PM
chevy 350 starter problems!!! zipfactor Engine 19 09-24-2008 08:01 AM
Starters And Vehicle Starter Problems Dutchman Electrical 3 07-26-2004 02:34 AM
starter problems John Boy Engine 6 05-19-2003 05:42 PM
