starter question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2007, 06:14 PM
starter question
What is the voltage I should see at the starter. I'm currently seeing 12.8. i'm getting a clicking noise but no engagement of the starter. This is a new MSD starter with only about 20 starts- could it be that I have a bad solenoid?? Oh sorry i'm working with a chevy 350.
Old 09-16-2007, 06:35 PM
poncho62's Avatar
Wiki Edits: 5
On the large terminal on the starter, you should see the same voltage as at the battery. 12.8 is about right. When granking the key, you should see about the same at the small terminal closest to the engine block. If you have voltage there, there is a problem in the solenoid or the starter itself.
Ontario Rodders
Old 09-16-2007, 09:21 PM
Agree, but some other possibilities?
Agree with Poncho, there's about a 90% chance of that solenoid being bad.
If it's not though, I'd check the battery to see if it tests ok under load.
Finally, if the battery cables are old, corroded(wire inside insulation), too small in diameter, terminals not clean, etc, they may not be able to carry the load on demand.
I'd take take a trip to my local parts store that tests parts, and take that solenoid down to see if they can test it, take the battery down to have it tested under load, and unless someone upgrade those battery cables recently, replace the battery cables for the heck of it with larger diameter cables.
If that don't do it, there's a remote chance that starter went bad or it got locked into the flywheel somehow. You can test it while it's out of the mount, but be careful, it puts out a lot of torque!
Steve
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 12 07-19-2007 08:07 PM
starter question inquiring_mind2 Electrical 1 10-27-2006 03:59 PM
Chevy SB Starter question tay Engine 3 09-02-2005 07:08 AM
Starter Question malibuman66 Electrical 1 07-16-2004 01:22 PM
Starter solonoid question???? HemmiGremmie Electrical 4 08-29-2003 03:46 AM
