Starter question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2008, 05:55 PM
Starter question
Hey guys so I got one of those high torque mini starters a few months ago brand spanking new for like $400 for my SBC 383. I haven't even drove the car yet just fired it up a couple times and now when I go to turn it over the starter just makes the "click" sound and nothing spins. Does this mean the solenoid is stuck already?? I've hardly had the bloody thing for 2 months and its barely been used and all it does is click when I hit the key. The battery is at full charge so I have tried tapping the solenoid with a hammer but the starter still just clicks. What should I do to fix this and what exactly is the problem here, an explanation of what is wrong would be nice.
Thanks,
Keith
Old 11-20-2008, 08:17 PM
302 Z28's Avatar
Sounds like you need to contact whomever you bought it from and inquire about a replacement. What brand is it? I have a Powermaster Ultra Torque and could not be more pleased with it.
Vince
Old 11-20-2008, 08:40 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Before you start beating it up with a hammer, or sledge hammer, of your choice.
Check your battery cable connections, positive and ground, and make sure you have clean and tight connections at the block and starter.
You might even need a ground wire from a starter mounting bolt to the frame.
Old 11-20-2008, 09:51 PM
I have that exact same starter, the powermaster, it comes with a 1 year warranty so I should take it back.
Thanks guys.
starter question inquiring_mind2 Electrical 1 10-27-2006 03:59 PM
Chevy SB Starter question tay Engine 3 09-02-2005 07:08 AM
Starter Question malibuman66 Electrical 1 07-16-2004 01:22 PM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 05:48 PM
Starter solonoid question???? HemmiGremmie Electrical 4 08-29-2003 03:46 AM
