starter question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2011, 07:42 PM
Babyburr's Avatar
starter question
Have a 300 HP Chevy. Should I go with hi-torque mini starter for weight savings and the torque, or should I just use a regular chevy starter?
Opinions for each. Pros and Cons
Thanks guys
Old 06-27-2011, 07:23 AM
I guess that all depends. I have both starters on different cars. And one--my 485hp Ford 460 had a real hard time turning over --especially when warm--even though the starter solenoid is away from heat and I was using a heat temp protective blanket on the starter itself etc--so I went with one of the lesser expensive JEgs units and now-and for a couple years-- it works great. No more hesitation in turning over the motor no matter the heat.
And in another I'm running a Chevy 350 OEM horse power and have used the OEM starter for a decade and never had any issues with the starter.
So I guess you might try the OEM starter--if you have it--and if you see issues then go and buy the hi torque. For my money in general I've not seen a down side to these hi torque units.
In my 460 Ford 10.5 compression I went with the Jegs Ford V8 Pro Start'R #1008, but probably any appropriate good brand name is just as good.
Tom
Old 06-27-2011, 06:43 PM
bubbahotep's Avatar
If you have headers or plan to get them then the high torque are usually the best option for clearance and heat resistance. Overall you do get what you pay for so the high torques are usually an easier and quicker start because they really turn the motor
starter grinding update Powermaster starter question RossR90 Engine 2 08-11-2008 02:46 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 02:44 PM
Starter question mrl Electrical 6 08-04-2007 05:23 PM
starter question njbloodline666 Engine 7 04-06-2005 06:39 PM
starter question Dubz Engine 4 05-02-2004 06:00 PM
