Starter question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2013, 11:03 PM
396chevelle's Avatar
Starter question
I have a fairly new 496 that I installed a mini high torque starter that will sometimes crank the car perfect, but sometimes it just made a clanking noise. So, I crawled under the car and watched it as I had someone turn it over. Cause I thought it might have had a bad solenoid, but the starter is fine what's happening is sometimes when the starter teeth go to make contact with the flywheel the teeth actually hit the flywheel teeth square on. Basically two teeth on the starter gear hit the backside of two teeth on the flywheel. But when it actually lines up it fits the groove like a glove and turns over great. Sometimes I have to crawl under the car an spin the gear a little to catch the grove once it starts hitting. I've tried shimming it from one extreme to the other. It's a 168 tooth flywheel and the starter is supposed to be ok with it. I really shouldn't need to shim it anyway. Its my first time seeing one mesh up perfect sometimes and other times it won't mesh up at all. Any suggestions? I wonder if the gear is to close to the flywheel and doesn't have enough room to spin and catch the teeth at times because it basically shoots straight out and then hits the flywheel. I'll measure it tomorrow. The groove clearance is good (Teeth to Teeth), but I'm not sure about the gear to flywheel distance. If I had to guess I would say 1/4 of an inch. Thanks in advance for the replies!
Old 03-13-2013, 05:37 AM
Thanks fbird for the reply. I was going to file it down, but wasn't sure if it would help. Ill give it a shot it shouldn't take much. Hopefully, it will do the trick. If not I'm going to Order me another stock starter for it.
Old 03-13-2013, 06:21 AM
Bonneville462's Avatar
Are you sure the flex plate is on the right way? Maybe the solenoid isn't strong enough to force the bendix to mesh? Try putting a set of jumper cables from the battery negative to the engine block..
If you need another starter, check out the Robbmc, it comes with an optional pinion support.. Good luck..
Welcome to RobbMc Performance Products
starter question Babyburr Electrical 2 06-27-2011 06:43 PM
Starter question sexypizzaman Electrical 3 11-20-2008 09:51 PM
starter grinding update Powermaster starter question RossR90 Engine 2 08-11-2008 02:46 PM
Starter question mrl Electrical 6 08-04-2007 05:23 PM
starter question inquiring_mind2 Electrical 1 10-27-2006 03:59 PM
