starter question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2004, 05:49 PM
Muscle car fan
starter question
ok, went and fired up the car today, but had a little bit of a problem (as always).
The starter motor does not want to spin every time, every time you can hear the starter solenoid click and engage, but it doesn't allways spin to turn the motor over, and i think playing with the car for half an hour would get stressful if it happens often.
sometimes it'll turn over fine, but then if the car didn't start it may not turn over on a second try.
Would the brushes in the starter motor be sticking (tapping the starter with a hammer doesn't help), could it be a problem in the wiring to the motor or inside the unit, and/or should i just get a replacement mini-starter for my motor (74 351W if that matters)
'74 Gran Torino Project
351W, c6 trans, 9"
Old 05-02-2004, 05:54 PM
poncho62's Avatar
Wiki Edits: 5
Check your solenoid and all your electrical connections. Also, the magnectic part of your starter may be corroded or sticking.
Old 05-02-2004, 05:55 PM
arch's Avatar
My bike has 4wheel disc brakes
Just a thought, did you check the battery for enough power? I had that exact problem with my starter, it would engage, but wouldnt turn the engine. I replaced the battery, and it hasnt given me a problem since. And the more I would try to make it turn, the less it wanted to.
Old 05-02-2004, 05:58 PM
DoubleVision's Avatar
As said before, check the connections, especially the grounds.
Old 05-02-2004, 06:00 PM
Muscle car fan
no no, the battery is 100% still, and after you jiggle just about everything, and turn the motor by hand, and smack everything and when the wind is just right, and you hold your tounge a certain way, it'll work fine and turn the car over wonderful.
so i doubt it's the battery
351W, c6 trans, 9"
