Starter Relay Q's - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2012, 02:44 PM
dirty dixon's Avatar
Starter Relay Q's
So I have been given this truck. I know very little about it yet. It is a 95 Ford F-150 with a supercharged 351 C & Auto Trans. There is an issue with it starting. I picked this truck up at a shop where it just got a new transmission put in. There was a note in it when I got in that said if the truck doesn't start jump the starter relay.
I drove it a few time and occasionally had issues with it starting. I would climb under the truck and push in on the wires running from the starter. Then the truck would start.
Well that gets old quick and I will need to address the problem when I start driving it on the reg.
1.) Does it sound like I should just replace the starter relay?
2.) If so is there a particular one I should replace it with or are they universal?
3.) What exactly does it mean to jump the starter relay?
Any insight would be helpful. thanks.
Old 03-29-2012, 05:25 AM
bondo's Avatar
Ayuh,.... Sounds like loose, corroded wires....
Remove, 'n clean the 1 yer wigglin'....
Ford Starter Relay Ground boris_thespider Electrical 1 02-11-2010 08:48 PM
Ford starter solenoid/relay Irelands child Electrical 12 05-30-2008 08:14 AM
Starter relay questions professor-patrick Electrical 13 08-23-2006 12:14 PM
Ford starter relay dbierman Electrical 3 01-17-2005 06:49 AM
MELTED STARTER RELAY Jim69Mustang Electrical 2 03-31-2003 04:35 PM
