starter saver... HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2012, 07:23 PM
bought a new msd digital 6al and a starter saver to run with a locked out distributor, when i hook up the starter saver it seem to have a occasional problem of not working, i have good grounds and good power. has anyone ever had this problem before
Old 02-25-2012, 03:26 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
What is a starter saver?
What is a locked out distributor?
vicrod
Old 02-25-2012, 05:36 PM
I believe it is a set to retard the timing while cranking,because the engine is full advanced
Old 02-25-2012, 09:35 PM
reply
it is a electronic device used to retard timing at the point of start up due to the distributor being set at full advance
MSD Starter Saver skizot Engine 5 10-18-2010 07:17 PM
chassis saver swvalcon Hotrodding Basics 1 10-14-2010 06:41 PM
Chassis Saver mattmanuel Body - Exterior 2 01-30-2006 12:25 PM
case saver maiors2 Transmission - Rearend 1 05-02-2004 11:13 PM
Hot Rod Screen Saver Stan Roberts Engine 2 02-16-2003 08:59 AM
