-   -   starter shiming due to align boring? (http://www.hotrodders.com/forum/starter-shiming-due-align-boring-43797.html)
Jared 07-19-2004 11:32 PM
ever since i had my block align bored i have to shim the out side edge of my starter to get the gears to mesh and its still loud, i dont dare shim it any more, i think the more angle i put on it the less starter touches the block and the weaker the connection between them is. I was thinking that if i found an old starter that fit and milled the mounting pad down a bit then shimmed it back to fit i might get a better connection. any thoughts or has anyone else had this problem? with all the work i have in this engine the loud starter is embarrassing. thanks.
bonuts 07-19-2004 11:36 PM
What engine is it? 400 SBC's are notorious for starters needing shims. Modified block or not.
bonuts
subman17 07-19-2004 11:55 PM
One thing to try also is to get a cast iron nose starter instead of aluminum or steel nose like most of them. I had this problem on my rebuilt 350. The cast iron nose starters are 1/8th of an inch closer to the flywheel from the starter shaft centerline( At least the ones we measured at the parts store were)
