Starter spins....sometimes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2009, 09:28 AM
97 C1500....5.7 vortec
A few days ago, returning from a fishing trip, my starter went out. When I tried to start it, the starter would just spin.
Well, trying to save a buck, I decided to fix the starter (or try). So, I tore it down and noticed that the clutch drive assembly needed replacing.
I ordered the part, picked it up and installed it. After putting the starter back together (or so I thought) I installed (without testing) and gave it a whirl. Well, no whirl came, just a single click and then nothing. So I pulled it back out, tore it back apart and found that I hadn't put the brushes in their holders , which in turn had burned up my solenoid. So, I bought a new solenoid, slapped it on and reinstalled the starter. And she started!!!!....
But, the next time I went to start it, the starter just spun....I gave it a few more goes and it would alternate between spinning and catching for a few rotations before slipping and spinning again. I can sometimes start it on the first try....other times it will take a few tries.
So, I pulled the starter off AGAIN! Tested it, and everything seems to be working. The pinion extracts far enough that it should be ingaging the flywheel....I can see that when it does extract that it is engaging fully.
Any idea's???? Do I need to just chunk this starter and get another, or is there still hope? I've already dropped this much work into it, not to mention the $40 CDA and $16 solenoid....
Old 03-14-2009, 10:24 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Check your flex plate for out of round/missing teeth.
Rich
Old 03-14-2009, 10:30 AM
I checked the fw for any damage...having my buddy rotate the engine as I did....I saw no missing teeth or any other type of damage....
Old 03-14-2009, 11:06 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I am sure the atarter was doing fine before.so if the funds are there i would go buy a new starter and solve the problem.nothing worse then having to keep yanking the starter over and over. cole
Old 03-14-2009, 11:14 AM
I'm on my way out the door to do just that!!!!
Old 03-14-2009, 12:15 PM
staleg's Avatar
Last journal entry: Hand brake
This happened on my '96 Chevy Astro a well.
I bought one of those OEM looking, cheap new ones on Ebay. It lasted a week. Then I bought one that was remanufactured in The US instead and that one worked just fine.
Old 03-14-2009, 12:30 PM
Bought a new one with a lifetime warranty....starts up no problem now....thanks for all the help folks....
Old 03-14-2009, 01:16 PM
Big Don's Avatar
starter problem
From your pictures:
It looks like you forgot to repair the real problem. High mica strips on the commutator.
Will cause slow engagement, dead spots, no start, or spinning with no engagement.
Fix: Put the communtator in a vise. Make a cutter from a hack saw blade and the cut the mica that lies beteen the commutator poles. Be sure to cut relief at at least 1/4" deep. Do not worry about causing a small abrasion on the sides of the brass, because this will be corrected by sanding the commutator to clean it up so the brushes will reseat. If you do not clean the commutator before reassembly the brushes will bounce and chatter and you could still have the same problem.
Usually there are just a couple of things that go wrong with starters. Bad bendix drive, bad or worn brushes, solenoid and faulty commutator. Unless it has been overheated the main feild windings seldom go bad.
Another Chevy Starter Issue (pic) Bluecollarron Engine 15 10-07-2013 11:12 PM
Installing a mini starter on my Chevy vern kelly Electrical 5 09-09-2009 02:41 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 02:44 PM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 08:07 PM
Starter spins but doesn't engage Z-Money Pit Engine 7 07-29-2006 07:08 AM
