starter switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2012, 04:46 PM
starter switch
how do you get the steering column apart to get to the starter switch on an 82 chevy pickup?
Old 10-23-2012, 05:02 PM
poncho62's Avatar
Wiki Edits: 5
Usually on a GM, the switch itself is under the column near the brake pedal. It is built into the neutral safety switch. A rod runs up from it to the key.
Old 10-23-2012, 05:09 PM
Last journal entry: was hoping for better than this
x2
now if you mean the lock cyl. we need to know tilt or non tilt
Old 10-23-2012, 05:40 PM
EOD Guy's Avatar
X3..... it might be bolted to the column by 2 bolts/screws...... mark the switch's position before you remove them, it helps getting it back in the right spot when re-installing
remote starter switch moish Electrical 11 10-17-2012 09:24 PM
Starter or ignition switch? Novaman78 Engine 14 02-20-2006 01:48 AM
Starter Switch Nic1979 Interior 2 08-07-2005 05:02 PM
starter,ignition switch,or battery? impala65 Electrical 2 08-21-2003 04:25 PM
starter/ignition switch short? rabrawlins Electrical 6 05-13-2002 06:33 PM
