Doc here, OK confused as all heck here..too many changes in a single paragraph.. Let me see if I got it right..you want to temp wire an 80's switch to an Ididit plug...(I think...) Try this: Ignition switch coil (pink)= To the HEI... Ignition switch Power (red)=To the fuse link on the starter solenoid Batt Bolt. Ignition switch start (purple)=To the starter solenoid "S" terminal or neutral safety switch... Ignition switch ignition (brown)=To Alternator via fuse and resistor, through the idiot lamp.. Did I get that right? Is that what you need? If not post back with "Less" information..hopefully we can help more.. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Sorry I just reread my own post and confused myself!
OK lets clarify things a bit, the stock ignition switch is the slide switch that used to be bolted on the mid 80s column in which the white plug and the black plug... plug into (and the assorted colloured wires listed) this is the way it is set up now (I just ripped the mid 80's ignition switch off the old column when I put the ididit in) the three prong off,energized, spring loaded start (I,S,B labeled on the contacts) is the switch I want to wire. the engine and chassis and dash (with exception of the ign sw) is already wired, those are the labels of the wire that I need to trim off the plugs and wire into a old school 3 prong switch Better????.................... maybe???? |
Doc here,
I pulled a Standard mid 80's Diagram for a mid sized GM today.. If I got this right, you've done away with the column switch all together, and are going aftermarket panel mount (B, S, I) type switch... the stock 80 diagram shows:
To Convert it to the B,S, I switch..
I think that's the data you are looking for..If not we may have a syntax error between what you need and what I think you are looking for.. Doc
Doc here,
KEWL... Keep us updated! Doc
| Alternator Wiring question | 65Stanger | Electrical | 8 | 04-29-2006 02:28 AM |
| Neutral Safety Switch and Starter ???? | reflog | Electrical | 12 | 04-26-2006 12:30 AM |
| 350 starter buzz | VEGA 3503508.5 | Engine | 10 | 04-03-2006 09:36 PM |
| Starter problems - unknown wiring | professor-patrick | Electrical | 3 | 10-09-2005 05:16 PM |
| stock wiring 1951 plymouth business coupe | jdockham | Electrical | 0 | 05-21-2004 10:35 AM |
