Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter teeth not fully engaging
Old 04-06-2013, 06:20 AM
454C10 454C10 is offline
The 153 tooth flywheel uses the starter with the bolts straight across from each other.
The 168 tooth flywheel uses the starter that uses a diagonal bolt pattern.
