Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter teeth not fully engaging
Old 04-06-2013, 06:32 AM
Mitchman's Avatar
Mitchman Mitchman is offline
Grand Master of the Universe
Originally Posted by Richiehd View Post
More likely a flywheel issue. Got pictures?
I turned the plate, it's the same all the way around. Pics at rest and extended. Both starters look the same. I've got a starter from Chevrolet Performance (Bowtie on the side) coming, but I really don't think it'll be any different.
The teeth engage about 1/2 the gear width as you can see. The mesh backlash is perfect.
The info sheet with each starter shows that the gap at rest should be .10 (.060 to .140). The gap measures +- .30. The ring gear won't last long like this.
If the mounting holes in the block are in the wrong place, I'll have to have a new mounting plate machined.
Thanks.
Name:	Starter bendix at rest.jpg
ID:	72945   Click image for larger version
Name:	Starter bendix extended.jpg
