Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter teeth not fully engaging
Old 04-06-2013, 06:33 AM
Mitchman Mitchman is offline
Grand Master of the Universe
Originally Posted by 454C10 View Post
The 153 tooth flywheel uses the starter with the bolts straight across from each other.
The 168 tooth flywheel uses the starter that uses a diagonal bolt pattern.
I've got 12.75"/153. The teeth mesh fine. See my 8:32 reply.
Thanks.
