Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter teeth not fully engaging
Old 04-06-2013, 10:18 AM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
By turning the plate, do you mean rotating it or flipping it over? Could it be installed backwards? The ring gear looks to be quite a distance from the block, but the pictures don't show the bellhousing/trans flange area.
You said the tooth mesh is fine, do you have the correct clearance with the starter is engaged? Not binding?
Semper Fi
