Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter teeth not fully engaging
Old 04-06-2013, 11:35 AM
Mitchman Mitchman is offline
Grand Master of the Universe
Originally Posted by 68NovaSS View Post
By turning the plate, do you mean rotating it or flipping it over? Could it be installed backwards? The ring gear looks to be quite a distance from the block, but the pictures don't show the bellhousing/trans flange area.
You said the tooth mesh is fine, do you have the correct clearance with the starter is engaged? Not binding?
Rotating. It's a crate engine, so backwards (flipped) isn't likely. 'Sides, the bosses at the torque converter bolt holes are impressed outward, towards the TC as they need to be.
Thanks.
