Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter teeth not fully engaging
Old 04-06-2013, 03:38 PM
Mitchman's Avatar
Mitchman Mitchman is offline
Grand Master of the Universe
Originally Posted by MouseFink View Post
Besides the number of gear teeth and overall diameter, there are two types of flex plates. One flex plate has a "flat" crank flange bolt circle with a spacer between the crank flange and the flex plate, and it uses longer bolts. The other has a "dished" crank flange bolt circle. Just something to think about because I have see this happen before.
Spacer, GM 12563532 (1 spacer)
Bolts, GM 11569956 (pack of 10 bolts) *
*Some dealers will break up a package of parts and some won't.
Dished here. Flipping it over would move the ring gear further away from the starter. I'd love to see a coupla shims twixt the crank and plate.... none to be found though. Thanks.
