Starter teeth not fully engaging - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-06-2013, 07:43 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I don't know, so asking, is there a difference between Vortec and early SBC starters? I see some mini starters listed do not work with LS motors.
Semper Fi
  #17 (permalink)
Old 04-08-2013, 12:17 PM
The difference is the pre 86 and post 86 flexplates. Pre 86 had the 2 piece RMS and the post 86 had the 1 pice RMS.
The 1 piece RMS required the round crank end which necessitated the flexplate/flywheel with the welded on weight to make up for teh weight that was on the 2 piece RMS cranks.
I piece RMS left, 2 piece RMS right
I piece RMS
400 2 piece RMS
There isnt any difference between Vortec(1996-1999 305/350) and non-Vortec (1986-1995) flexplates.
I installed a reman starter on my 1997 Vortec 350 truck, and after a short while it started to make horrible noises as the starter gear wasnt fully engaging the flexplate gear.
Never did solve that issue.
peace
Hog
  #18 (permalink)
Old 04-08-2013, 12:21 PM
Originally Posted by MouseFink View Post
Besides the number of gear teeth and overall diameter, there are two types of flex plates. One flex plate has a "flat" crank flange bolt circle with a spacer between the crank flange and the flex plate, and it uses longer bolts. The other has a "dished" crank flange bolt circle. Just something to think about because I have see this happen before.
Spacer, GM 12563532 (1 spacer)
Bolts, GM 11569956 (pack of 10 bolts) *
*Some dealers will break up a package of parts and some won't.
This spacer is only for GEN 3/4 engine use or transmissions that were behind GEN 3/4 engines.
It wont help in this instance. The flexplates you are talking about are for GEN 3/4 use as well.
peace
Hog
  #19 (permalink)
Old 04-08-2013, 01:17 PM
Mitchman's Avatar
Grand Master of the Universe
peace
Hog
Hogg, Thanks. Nice to see someone post some useful info. One-piece for me. I've got another (3rd) starter coming supposedly from Chevy Performance. If it doesn't engage any more fully, I'm going to have a machine shop bush and re-drill the bolt holes in the alum. mounting plate. This should be a roll-off-the-wall easy job and no matter the cost, solves my dilemma - time to move on.
I'll post later for posterity.
  #20 (permalink)
Old 04-08-2013, 02:42 PM
Quick Time #RM-935 flex plate spacers. Kit of 5 steel spacers from .030" to .125" thick.
Fits: 1974-1985 Chevrolet V8 (1-piece seal)
  #21 (permalink)
Old 04-08-2013, 06:06 PM
Richiehd's Avatar
JS-70
Mousefink, I dont think that is going to help him, flywheel is already too far out, with no shims.
  #22 (permalink)
Old 04-09-2013, 11:10 AM
Mitchman's Avatar
Success!!
Chevrolet Performance starter fits like it should, teeth mesh fully, backlash is good. The other two 'off brands' are going back.
Glad to get this off the list.
Name:	Starter bendix fits properly.jpg
  #23 (permalink)
Old 04-09-2013, 12:12 PM
Richiehd's Avatar
JS-70
Yeah look at the difference between pic 1 and pic 3. Pic 1 the starter looks like it mounts 1/8 inch further forward (away from flywheel) than in pic 3. Good call Mitchman, I guess thats a starter for earlier motor? or just Chinese engineering? Thankl for updating us.
  #24 (permalink)
Old 08-11-2014, 12:27 PM
Starter prob here too!
Mitchman, When you said you ordered another starter with a bowtie on the side, Was that from jegs/summit or was it from a place called chevrolet performance? I have the exact same problem.
Thanks
  #25 (permalink)
Old 08-11-2014, 02:34 PM
Mitchman's Avatar
Thanks
Chevy Performance part from Jegs (black with the Bowtie). Unfortunately it doesn't come in chrome.
I started 'er up last week... teeth mesh as they should. No surprises.
You found the off-brand stuff doesn't work too, huh?
809-12361146 - JEGS High Performance
  #26 (permalink)
Old 03-06-2016, 02:58 PM
Same Issue
I am having the exact same situation. I mentioned it to a mechanic friend and he said it would not be a problem.
  #27 (permalink)
Old 03-06-2016, 05:48 PM
Mitchman's Avatar
Rethink this. Flywheels are a PAIN to replace. Why would you want to put 100% of the starter's torque on only 50% of the gear's available surface?
Starter not engaging? wicat3 Transmission - Rearend 1 11-01-2011 10:31 PM
Starter not engaging williamC-3 Electrical 7 09-23-2010 12:42 PM
starter not engaging, just scrapping?? 84Z Engine 5 04-03-2007 05:42 PM
starter-flywheel engaging adrock430 Electrical 2 08-22-2005 12:25 AM
Starter not engaging flywheel dpjmw Engine 1 12-19-2003 10:21 PM
