-   -   Starter teeth not fully engaging (http://www.hotrodders.com/forum/starter-teeth-not-fully-engaging-231525.html)
Mitchman 04-05-2013 02:12 PM
I'm just putting the jewelry on a new 350 HO, Vortec crate engine. I'm finding the 2 starters I've tried (2 different models from Jegs) are failing to fully engage the teeth on the ring gear. The solenoid is not pushing the pinion gear far enough to fully mesh. At rest, there is a 1/4" gap (Should be 0.10), and the gears engage only about half their width when extended.
One guy at Jegs says he's heard of this but there's nothing to worry about, the other says he's never heard of this and any starter for the 350 crate with in-line bolt holes should work fine, never had a problem.
This can't be right. Anyone else run into this? What to do?
Possible the tapped holes in the block are 'off'?????
Richiehd 04-06-2013 04:55 AM
More likely a flywheel issue. Got pictures?
454C10 04-06-2013 06:20 AM
The 153 tooth flywheel uses the starter with the bolts straight across from each other.
The 168 tooth flywheel uses the starter that uses a diagonal bolt pattern.
Mitchman 04-06-2013 06:32 AM
2 Attachment(s)
I turned the plate, it's the same all the way around. Pics at rest and extended. Both starters look the same. I've got a starter from Chevrolet Performance (Bowtie on the side) coming, but I really don't think it'll be any different.
The teeth engage about 1/2 the gear width as you can see. The mesh backlash is perfect.
The info sheet with each starter shows that the gap at rest should be .10 (.060 to .140). The gap measures +- .30. The ring gear won't last long like this.
If the mounting holes in the block are in the wrong place, I'll have to have a new mounting plate machined.
Thanks.
Mitchman 04-06-2013 06:33 AM
I've got 12.75"/153. The teeth mesh fine. See my 8:32 reply.
Thanks.
68NovaSS 04-06-2013 10:18 AM
By turning the plate, do you mean rotating it or flipping it over? Could it be installed backwards? The ring gear looks to be quite a distance from the block, but the pictures don't show the bellhousing/trans flange area.
You said the tooth mesh is fine, do you have the correct clearance with the starter is engaged? Not binding?
Mitchman 04-06-2013 11:35 AM
Rotating. It's a crate engine, so backwards (flipped) isn't likely. 'Sides, the bosses at the torque converter bolt holes are impressed outward, towards the TC as they need to be.
Thanks.
Richiehd 04-06-2013 02:01 PM
Is there a shim in the body of the starter? Some of those mini starters you could shim the motor part forward or back...Just an idea. That thing needs to 1/4 inch or so
Richiehd 04-06-2013 02:03 PM
Im looking at the flywheel again are you sure its on right? it looks awefull far out,
Mitchman 04-06-2013 02:20 PM
It's right. If I flipped it, the TC would have to bolt up to concave areas.
Mitchman 04-06-2013 02:21 PM
No shims, 'cept the ones loose in the box.
MouseFink 04-06-2013 02:44 PM
Besides the number of gear teeth and overall diameter, there are two types of flex plates. One flex plate has a "flat" crank flange bolt circle with a spacer between the crank flange and the flex plate, and it uses longer bolts. The other has a "dished" crank flange bolt circle. Just something to think about because I have see this happen before.
Spacer, GM 12563532 (1 spacer)
Bolts, GM 11569956 (pack of 10 bolts) *
*Some dealers will break up a package of parts and some won't.
Mitchman 04-06-2013 03:38 PM
Dished here. Flipping it over would move the ring gear further away from the starter. I'd love to see a coupla shims twixt the crank and plate.... none to be found though. Thanks.
Richiehd 04-06-2013 04:47 PM
Vortec flywheel different than earlier flywheel? I think it has weights on it. Just asking, I dont know
Mitchman 04-06-2013 05:25 PM
Yep, it's got a weight on it.
