Starter teeth not fully engaging - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2013, 02:12 PM
Grand Master of the Universe
I'm just putting the jewelry on a new 350 HO, Vortec crate engine. I'm finding the 2 starters I've tried (2 different models from Jegs) are failing to fully engage the teeth on the ring gear. The solenoid is not pushing the pinion gear far enough to fully mesh. At rest, there is a 1/4" gap (Should be 0.10), and the gears engage only about half their width when extended.
One guy at Jegs says he's heard of this but there's nothing to worry about, the other says he's never heard of this and any starter for the 350 crate with in-line bolt holes should work fine, never had a problem.
This can't be right. Anyone else run into this? What to do?
Possible the tapped holes in the block are 'off'?????
Old 04-06-2013, 04:55 AM
Richiehd's Avatar
JS-70
More likely a flywheel issue. Got pictures?
Old 04-06-2013, 06:20 AM
The 153 tooth flywheel uses the starter with the bolts straight across from each other.
The 168 tooth flywheel uses the starter that uses a diagonal bolt pattern.
Old 04-06-2013, 06:32 AM
I turned the plate, it's the same all the way around. Pics at rest and extended. Both starters look the same. I've got a starter from Chevrolet Performance (Bowtie on the side) coming, but I really don't think it'll be any different.
The teeth engage about 1/2 the gear width as you can see. The mesh backlash is perfect.
The info sheet with each starter shows that the gap at rest should be .10 (.060 to .140). The gap measures +- .30. The ring gear won't last long like this.
If the mounting holes in the block are in the wrong place, I'll have to have a new mounting plate machined.
Thanks.
Name:	Starter bendix at rest.jpg
ID:	72945   Click image for larger version
Name:	Starter bendix extended.jpg
Old 04-06-2013, 06:33 AM
I've got 12.75"/153. The teeth mesh fine. See my 8:32 reply.
Thanks.
Old 04-06-2013, 10:18 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
By turning the plate, do you mean rotating it or flipping it over? Could it be installed backwards? The ring gear looks to be quite a distance from the block, but the pictures don't show the bellhousing/trans flange area.
You said the tooth mesh is fine, do you have the correct clearance with the starter is engaged? Not binding?
Semper Fi
Old 04-06-2013, 11:35 AM
Rotating. It's a crate engine, so backwards (flipped) isn't likely. 'Sides, the bosses at the torque converter bolt holes are impressed outward, towards the TC as they need to be.
Thanks.
Old 04-06-2013, 02:01 PM
Richiehd's Avatar
JS-70
Is there a shim in the body of the starter? Some of those mini starters you could shim the motor part forward or back...Just an idea. That thing needs to 1/4 inch or so
Old 04-06-2013, 02:03 PM
Richiehd's Avatar
JS-70
Im looking at the flywheel again are you sure its on right? it looks awefull far out,
Old 04-06-2013, 02:20 PM
It's right. If I flipped it, the TC would have to bolt up to concave areas.
Old 04-06-2013, 02:21 PM
No shims, 'cept the ones loose in the box.
Old 04-06-2013, 02:44 PM
Besides the number of gear teeth and overall diameter, there are two types of flex plates. One flex plate has a "flat" crank flange bolt circle with a spacer between the crank flange and the flex plate, and it uses longer bolts. The other has a "dished" crank flange bolt circle. Just something to think about because I have see this happen before.
Spacer, GM 12563532 (1 spacer)
Bolts, GM 11569956 (pack of 10 bolts) *
*Some dealers will break up a package of parts and some won't.
Old 04-06-2013, 03:38 PM
Dished here. Flipping it over would move the ring gear further away from the starter. I'd love to see a coupla shims twixt the crank and plate.... none to be found though. Thanks.
Old 04-06-2013, 04:47 PM
Richiehd's Avatar
JS-70
Vortec flywheel different than earlier flywheel? I think it has weights on it. Just asking, I dont know
Old 04-06-2013, 05:25 PM
Yep, it's got a weight on it.
Starter not engaging? wicat3 Transmission - Rearend 1 11-01-2011 09:31 PM
Starter not engaging williamC-3 Electrical 7 09-23-2010 11:42 AM
starter not engaging, just scrapping?? 84Z Engine 5 04-03-2007 04:42 PM
starter-flywheel engaging adrock430 Electrical 2 08-21-2005 11:25 PM
Starter not engaging flywheel dpjmw Engine 1 12-19-2003 09:21 PM
