Starter turns slow when hot - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2011, 05:31 AM
dasyhard's Avatar
My starter is not high torque so it turns slowly when hot, even after I've been parked for 2-3 hours. But the next day is turns normally and I think it's time to change it. I haven't the slightest idea what brand is it. All I know is that the solenoid is mounted on the bottom of this starter so a friend of mine told me that is a wierd one. My motor is a 454 LS6, 11:1 compression, and a high lift hydraulic cam. I'm looking for a high torque starter with the solenoid mounted on the bottom. Can anyone give me some tips on name brands with this application?
Old 02-07-2011, 06:15 AM
poncho62's Avatar
Wiki Edits: 5
Never saw a Chevy starter with the solenoid mounted on the bottom.......
You may need a starter, but it also could be the heat from the headers....a heat shield between the starter and exhaust may help......A lot of people also put on a remote solenoid (Ford type)
Old 02-07-2011, 06:36 AM
dasyhard's Avatar
Thank you for your feedback. I think in my case since I live in Hawaii I should seek locally. That way if I run into problems with the fitting and clearance, I can return it without shipping charges. And yes, the headers are near the starter and I will definitely install a heat shield around the new starter.
Old 02-07-2011, 07:36 AM
Not sure if the LS6 has the same bolt pattern as a Mark IV big block. But I used a starter for a 2000 S10 pick up truck. High torque mini starter.
Old 02-07-2011, 09:34 AM
302 Z28's Avatar
Good idea, but invest in a QUALITY mini starter. Some of the offshore mini starters available at auto parts stores will not give good results. One of the issues is that the bendix will not dis-engage as soon as the engine starts and drags a bit. Look for a genuine AC Delco starter and you may be alright.
Vince
Old 02-07-2011, 10:43 AM
jeffery wells's Avatar
you may want to install a remote starter solenoid kit, if drag is a big player in your application then the kit would kick the starter off at 1000rpm and kick it on if the rpm drop below 600, but that's just the basic kit, you can have then higher or lower depending on what you'r idle is, and yes, a shield would be best if it's getting to hot.
Old 02-07-2011, 03:35 PM
dasyhard's Avatar
Once again, thanks gentlemen. That's exactly what I'm leaning on; a mini high torque starter. In my past history, I had a 454 mounted in a 92 chevy truck and I used the Tilton mini starter. It worked great but that starter was costly (almost $400). If anyone out there has a 454 with a mini starter, please give me the brand name so I can narrow my search. At the same time I'll jack-up my car to take a snapshot of my starter so I can take it to the auto parts store to give them an idea on what I'm seeking. Thanks.
Old 02-07-2011, 03:45 PM
I would suggest you do a voltage drop test on the wiring to and from the starter. This is a web page on how to do voltage drop tests, it is a little bit of a long read, but very informative:
http://www.vernco.com/sparks/id606.htm
Old 02-07-2011, 03:56 PM
NOlowrider's Avatar
US Navy-Retired
This is what I have on my BBC. Works great. I also have the heat shield.
http://www.summitracing.com/parts/SUM-829100/
Old 05-25-2011, 12:55 AM
dasyhard's Avatar
Replaced starter
Just wanted to thank all of you for your input and sorry for the lateness in posting the results. I replaced the starter (MSD high torque) and battery (Sears Platinum Die-Hard). It starts fine now and the starter is not located near the headers like the previous one did.
starter slow cranking bigdog7373 Engine 11 07-11-2010 09:12 AM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 03:44 PM
Farna turns 44... schnitz Off-Topic 2 12-08-2005 08:41 PM
Hoodoo turns 52! schnitz Hotrodders' Lounge 1 05-23-2005 07:50 AM
rebuilt motor turns over slow... Trav Engine 3 05-26-2004 07:20 PM
