Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter Whine..Sometimes Nothin'
Old 09-05-2011, 09:19 AM
91CamaroDude 91CamaroDude is offline
The starter test i ran was from the Positive cable to the big terminal, from there to the solenoid, i said from the battery but it was already ran to the big side of the terminal. So big terminal to solenoid terminal, and just whines. Now i will check for any wiggle when i get off work today, because that would make since. As far as corrosion, the starter is a new remaned from the parts store, and before i hooked up the positive wire to the big terminal i cleaned it up spotless so i know there is no corrosion. The connections at the firewall are all set in place and good to go, i have checked this more than once. The ground is ran to an accesory hole on the head, just for quick tests instead of hiding it back and then having a hard time to get to it. Would the ignition switch (being the steering column knuckles are loose) have any kind of play in this mess at all?
