Starter wire got extremely hot fried the ground wire - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2012, 04:34 PM
Hi guys I have an s10 with a sbc. Just went to start truck and it fired but saw and smelled something under hood.. One of the wires or all of the wires (idk) got extremely hot and melted the plastic wire loom tubing. I also the in a glance the ground wire from the battery to the body smoking and it obviously fried that because the radio was starting to fade. I do know that I was concerned about replacing the ground before because it smoked a little on occasion but do you think it just couldnt handle the current from being wore out already and the starter wire got extremely hot? or is my starter going bad?? Remember its the ground from the battery to the body not the thick negative terminal itself..
Old 08-03-2012, 06:47 PM
S10 Racer's Avatar
http://www.warsprints.com
Where is your battery negative (big) cable grounded to on the truck? It should be grounded to the engine.
Old 08-03-2012, 07:32 PM
yes yes its grounded to the header but I think its called the ground strap maybe
Old 08-03-2012, 07:42 PM
S10 Racer's Avatar
The negative cable from your battery needs to be grounded to the engine block. Then you should have ground cables or straps from the engine to the frame and body. You can't have too many grounds but they all need to be the correct size and grounded properly. If you could post a picture of your engine compartment showing what you have it would be easier to diagnose. Never use a header bolt for a ground point. Header bolts come loose in time and will cause you problems.
Old 08-04-2012, 02:32 PM
Here it is. No power on inside of vehicle. bad ignition?
ID:	67199   Click image for larger version
ID:	67200   Click image for larger version
ID:	67201   Click image for larger version
ID:	67202   Click image for larger version
Ground strap or ground wire? impalaman63 Electrical 12 07-20-2011 01:00 AM
Ground wire on fire... south65ss Electrical 10 06-16-2010 08:18 AM
Fried wire from ignition to soleniod? frankenvette Electrical 4 07-31-2008 02:45 PM
Wire Diagram for points,starter,1 wire alt,and distributor plainhavoc Electrical 3 04-12-2006 02:13 AM
Ground Wire Getting hot when trying to start Double0svn Electrical 10 08-14-2004 09:55 PM
