Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter woes Again
Old 08-31-2004, 10:22 PM
dmc12mk3's Avatar
dmc12mk3 dmc12mk3 is offline
Last journal entry: Fixed some leaks
I might have missed this part, but I'll ask just in case it helps. Have you tried engaging the starter with it laying on your work bench? I usually hook a booster pack up to mine (gm's, not ford's) and touch a wire from the relay post to the + and see if everything is getting spun and kicked out properly.
I'm sure you could work up something similar with your remote solenoid and starter just to see.
