Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter woes Again
Old 09-01-2004, 04:16 PM
dollybud's Avatar
dollybud dollybud is offline
Thanks for the info. DMC I have bench tested starter. MI2600 it sits squarely when it engages as I have looked at the teeth when it meshs and freezes,and it looks fine starter teeth in flywheel straight and proper clearance. Its easy to check the clearance when it freezes in flywheel. Will take out all plugs and try. It's beginning to look like something internal,will keep the board informed.
