Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter won't start and fuel pump won't pump after engine reinstall
Old 02-13-2007, 11:47 AM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
Which small terminal on the starter are you connecting this wire from the ign switch to? Have you bench tested the starter?
It should be the one closest to the engine block.
