Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starter won't start and fuel pump won't pump after engine reinstall
Old 02-13-2007, 04:17 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Doc here,
You might check the Mallory site to see if a rebuild kit is available for that pump..It looks like the Pump portion is rebuild-able (the bottom part) but if the motor is not working, that may be another problem..
The motor drive may be stuck (if it draws current a lot when on, or the wire gets hot) and you may be able to free it by turning the gears in the pump assembly, but other than that , I'd say not too much you can do but replace it.
Doc
