Startin up an engine been sittin' awhile - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-19-2008, 12:15 PM
spark plugs don't go bad just sitting in a motor....
if the motor ran ok before it sat.... it will still run ok on those plugs....
the black will make the coil charge to a higher voltage to be able to jump the gap....
if they are still black after 500 miles it indicates a motor problem...
if ya just gotta go buy some new parts....go buy a new fuel pump...the pump rubber diaphram doesn't do well sitting dry for a long time
"if it ain't broke don't fix it"
  #32 (permalink)
Old 04-19-2008, 06:36 PM
Wiki Edits: 31
could indicate that too cold of a spark plug was used for the engine.
  #33 (permalink)
Old 04-20-2008, 12:33 PM
I didn't know if spark plugs went bad or not. Thats cool I dont have to get new plugs, I really dont have much money this month. Thanks for the tip. I'll defanatly use the old ones.
  #34 (permalink)
Old 04-20-2008, 03:19 PM
T-bucket23's Avatar
Wiki Edits: 26
If the plugs are black, I would look to see that the choke is opening.
I agree witht the above post, plugs dont have a shelf life. I have started engines that sat for 10+ years and as long as the plugs were not oil soaked, I re-used them.
On a long time stting idle car, I would be most concerned with the fuel system and getting the engine pre oiled.
Chet
  #35 (permalink)
Old 04-20-2008, 04:30 PM
Chet
Thanks chet for the info!
  #36 (permalink)
Old 04-21-2008, 12:31 PM
On this engine what cyl. would be cyl #1? (80's ford V6.)
  #37 (permalink)
Old 04-21-2008, 01:30 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
right side front. right side 1-2-3 left side 4-5-6
  #38 (permalink)
Old 04-21-2008, 02:30 PM
Thank you sir!
  #39 (permalink)
Old 04-22-2008, 09:57 AM
My 2 cents worth
Wiki Edits: 3
Originally Posted by smurbs
Thank you sir!
smurbs For your information: firing order is 1-4-2-5-3-6 clockwise rotation
  #40 (permalink)
Old 04-22-2008, 11:57 AM
Thanks again! Steve. Valuable info.
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 12:37 PM
Engine....whats it worth? chevyusa1 Engine 6 06-11-2007 06:43 PM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
