Startin up an engine been sittin' awhile - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2008, 09:44 PM
Okay, to start off the engine is in a 72 courier. Its not the original engine. It's a Ford V6. Looks to me like a 1980's mustang engine. Not quite sure of the size or year. I was planning to start it up, it's been sitting roughly a year maybe even two.
I know a few of you guys have started up an engine thats been sitting a long time. Maybe even more than a few.
Already:
Planed to replace carb, distributer and spark plugs oil/lucus oil stablizer.
Radiator is full.
Tranny fluid full.
Thanks in advance.
-dan
Old 04-16-2008, 09:48 PM
BORTI's Avatar
BLOWN 357
engine start
Sounds like its ready to fire.
Old 04-16-2008, 09:51 PM
Wiki Edits: 31
I'v woken up a lot of old engines... change oil, points/ condensor if it has them.. clean up carb a little.. hot start in the carb and fire it up
Old 04-16-2008, 10:00 PM
DoubleVision's Avatar
After you fire it up, do exactly as you would breaking in a new engine, raise the rpm to high idle, around 1800 RPM or better, then lower it down a few minutes, then back up again. Neglecting to do so will almost ensure the cam will go flat. Always cycle a sitting engine as you would a new one.
Old 04-16-2008, 10:21 PM
No A/c condensor. What is hot start?
Old 04-16-2008, 10:26 PM
What does it mean to cycle an engine?
Run it at 1800 RPM for how long?
Run at normal for how long?
I've never broken in a new engine,
if you've got any more info on that
ya should let me know.
THANKS GUYS!
-dan
Old 04-17-2008, 08:24 AM
Cycle it means run it at around 1800 rpm for about 3 to 4 minutes, then raise it to about 2200 rpm for the same amount of time, then back down to 1800. do this in a 20 minute time span. Keep your eye on coolant temps and oil pressure. This assures oil splashes everywhere it needs to. seen many engines sit for a long time then refired without being cycled, in almost every case the cam went flat.
Old 04-17-2008, 08:54 AM
Wiki Edits: 31
Starting fluid... not an A/C condensor, I'm talking about the condensor for the points ignition, if it is points ignition that is
Old 04-17-2008, 12:11 PM
I've never done this before but that really seems pretty straight forward. I have no idea if the RPM gauge works, is there an other way to make sure its at 2200?
Also should I be running 10w 30 or 40? *oil*
Old 04-17-2008, 12:13 PM
How will I know if it has points ignition?
Where will the condensor be found if I do indeed have one?
Old 04-17-2008, 12:50 PM
you don't have points or condenser...last points motors were around 1970
buy a clear plastic $5 gas filter and mount it at the fuel pump tank line inlet hose to catch the scale that's in the gas tank....
better yet use your 2gal lawn mower gas tank with fresh gas and a bit of carb/injector cleaner added and hook it up to the fuel pump inlet with a hose...
start the motor with the rad cap off...once warmed up there should be a "river" of coolant flowing telling you the thermostat did open...then put the cap on....
my $.02
a lighter wt oil (5W30) cleans better and faster because there is more gpm thru the motor....change the oil and filter after the 30 minute test drive
put your batt on a charger before trying to crank it....
kill the power to the ign so you can just crank the motor repeatedly for 30 seconds with one minute in between...about 5 times....that will pump oil to the valve train which is bone dry and wet the mains and cam bearings
once it does start just rev the motor 5 times...that throws oil onto the cam shaft
no need to replace anything till you know for sure it is broke if it has been sitting just a year!
if it's running at least "ok" after it's warmed up go for a 30 mile drive varying the mph..."all the fluids" need some "exercise" after sitting for a year and driving does that
hopefully the gas tank is low on fuel so you can just fill it up with fresh gas and let the motor burn out the now diluted stale gas
ps: if the plugs are easy to remove do it....before you do the repeated cranking to circulate oil...less load on the starter and the motor cranks faster throwing alot more oil to "prelube" the motor
Old 04-17-2008, 01:18 PM
my $.02
What is "scale"?
My gas tank is empty and not installed.
Thats a great way to tell if the thermostat is working! (thank you)
How would I go about cutting power to the ign?
Leave them out when I crank it? wont that throw oil all over my engine compartment?
Old 04-17-2008, 02:10 PM
When I start a motor that has not been run is some time, I do all the things mentioned already, Tune up, oil change, fuids etc. However, I also pull the plugs and put about a cap full of oil in each cylinder and prelube the engine by removing the distributor and using a drill with the correct socket to turn the oil pamp shaft. You can also do this by just cranking the engine w/o the coil wire attached so it doesn't start (as mentioned above). I prefer the drill way though as nothing is moving until everything is lubed up. This way the motor has oil throughout prior to starting. I also usually turn the crank with a breaker bar just to get the cylinder wall lubed a little after adding the oil in the spark plug holes. It will smoke a little at start up, but it will stop quick after the oil burns off. Also, when you changed the oil filter, did you fill it with oil before installing? (basics I know, but you never know) Just a little extra insurance.
Good luck
Old 04-17-2008, 02:26 PM
Good luck
Would I need a drill to turn the oil pamp shaft or could I use a wrench?
I have done nothing to this truck YET. Still in the planning stage. Good thing too, I didn't have any idea about all this info... Im still a newb Shh!
(dont tell anyone) ha ha.
I didn't know to fill the oil filter before installing. So I really dont mind hearing the basics.
Old 04-17-2008, 03:02 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
WAIT!!!!!
Now that I got your attention Definitely pull the distributor, buy an oil priming tool ($15) and spin the oil pump for a few minutes with a drill. Over the years, all the oil has drained out of critical places and you need to get oil in there before you hit it with the starter.
Also, pull the valve covers and using an oil can squirt oil on the cam lobes if you can. The cam lobes rely on oil slung from the crankshaft. They get little or no oil from anywhere else. They are a heavy friction area and running it before you get oil on those lobes can wipe them flat in one revolution. In normal operation when the car only sits for a few days or weeks at a time, enough oil remains on the lobes to be fine for the next startup, but when it sits that long you have direct metal to metal with no oil on the lobes.
Cam lobes for flat tappet cams are much like an egg hard on the outside, soft on the inside. They are made of relatively soft cast iron and the surface of the lobes is hardened. Once you score the surface of the lobes its all over.
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 01:37 PM
Engine....whats it worth? chevyusa1 Engine 6 06-11-2007 07:43 PM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 08:50 AM
