starting with the body - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2013, 06:27 AM
Last journal entry: steering box
Ready to get started on the model-A, guess the body comes off first,anyone got a sedan and done this give me a holler I am all ears.
Old 01-02-2013, 07:22 AM
Irelands child's Avatar
Not a difficult job regardless of whether it's a sedan, coupe or roadster, it's for all intents, the same. If it's fully stripped out, wiring disconnected, etc, there are several bolts down each side through the body floor and body framework channels. The bolts go through some mounting blocks then through the frame or frame brackets. While the fasteners all may be rusty and need to be cut, the only ones that may give you grief are the two on each side hidden by the cowl 'feet' as they are somewhat difficult to get wrenches on. Removing the doors (though never on a roadster - it WILL bend) will also aid as far as weight and access and if a solid body will not distort it. If it's a '30-'31, pulling the cowl cover/gas tank also helps with the access plus they need to come off eventually anyhow. Floorboards, steel or wood, should also be removed if possible - again, ease of access
Old 01-02-2013, 07:38 AM
Thank's
Cool man I will keep you posted on my progress.
Old 01-02-2013, 09:26 AM
killeratrod's Avatar
How about some pictures to start with. thank you!!
Old 01-02-2013, 01:36 PM
I will is it a big deal to put pictures on or pretty easy.
Old 01-02-2013, 05:33 PM
carolinacustoms's Avatar
Automotive Extraordinaire
The easiest way to post pictures is to use photobucket. Its free to set up an account. Once you get your pictures there just click on the bottom link on the share page and then paste it here. I have some pictures and a video of a 29 two door we done a while back with a 460 in it. I'll put some up when I get home tomorrow from the shop and get to my computer.
Old 01-02-2013, 05:49 PM
poncho62's Avatar
Wiki Edits: 5
How to post pictures and videos on Hotrodders.com
Ontario Rodders
Old 01-03-2013, 10:15 PM
Here's a few pics of the 29 I mentioned earlier.
Old 01-03-2013, 10:29 PM
A few more
starting a body shop business showtime1k Body - Exterior 15 06-13-2012 05:51 AM
v8toy starting body work on bug v8toy Introduce Yourself 4 01-11-2012 01:54 PM
Newbie starting body filler has questions 075turbo Body - Exterior 1 09-23-2010 04:41 PM
Starting Body Cleanup On 57 Ranchero NV57 Body - Exterior 5 05-08-2006 11:46 AM
First atempt at starting street rod...not starting. RodFather Engine 20 01-12-2005 09:18 AM
