Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starting body work- help requested!!!
Old 01-27-2013, 08:03 PM
bk005's Avatar
bk005 bk005 is offline
I only use them for set up and when Im holding a gap that needs to be larger than normal. I myself like a bit of gap in the metal, after it cools its going to suck up and when I weld acorss all the curves across a quarter like that it could be bad news. Plus I have to take them and grind the clamps surfaces flat before using them, they not very square, and if you use them when you shouldnt can screw you up more than they help you.
